I have a 2008 Sierra 1500 and looking at getting a bug guard for the truck. I want a smoke tinted one, but which brand to get? What do you guys suggest? What should I avoid?
Thanks.
i have one by stampede that looks pretty good and works.
purchased from my local dealer for around 50 dollars.
IMO, clear one with the back of it painted the color of the truck looks pretty good. Especially with the sharp color of your truck.
I have the GM one I got for about $70. I preferred it because it went up and around the chrome grill trim on the hood, rather that straight across the front like I had seen some aftermarket ones do.
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,155 Guests (See full list)
