Westin Hdx
Anyone have any experience or pics with the westin HDX grill guard?
I installed a black one on my 08 2500HD CC (black) about 2 mo. ago. I like it alot and it is really solid. Installed it myself and it was pretty easy with the help of a floor jack, some rolled up towels and a couple of bungee straps. Sorry no picks.
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 1,105 Guests (See full list)
