Po420 Code Is Back! Arrgghh!
jseabolt
I hate to keep throwing money at this van until the problem goes away. The check engine light keeps coming on and I keep clearning the code. It may go off for a week or come right back on with a couple of minutes.
It's the same nagging code PO420. O2 threshold to low.
So I ask the guy at Advance Auto does this code mean the O2 sensor is bad or is something upstream is setting it off and the O2 sensor is picking up on something?
He says one of the front O2 sensors are bad. So I change those and clear the codes. Well the van seems to run better and the light stayed off for a week. Now it's back on.
Dad says the van is getting 13 mpg on the highway and got around 20 when he bought it 10 years ago.
I asked this question the other day but didn't get much feedback. What is the normal operating temperature for a 98 Chevy van 350 small block engine.
Our 98 S-10 pickup at work appears to have the same temperature guage. It reads 210F at normal operating temperature. Dad's van reads at the quarter mark at normal operating temperature.
I'm thinking 210F is the normal operating temperature for a GM vehicle of this era and this van is running too cold. The heater seems to work fine.
Will a thermostat that is causing an engine to run at a too low a temperature set of a PO420 error code because it's using too much fuel because it never reaches normal operating temperature?
P0420 is a catalytic converter code - more than likely, the cat is smoked ... but there is a SLIM chance of the post-cat sensor being out of spec.
Misfires or rich conditions are cat killers. Seeing that your not throwing any misfire codes, this may have happened years ago .... or you've had that rich code for a while (13 mpg would indicate that) - excessive unburnt fuel, whatever the source, causes the cat temp to go so high that it melts & stops doing it's job. My money is on the cat. SORRY!
I didn't want to repeat myself (unless you have been keeping up with my posts) but a month ago the van appeared to be dumping an excessive amount of fuel into the exhaust. The code reader said random misfire. I was stumped so I decided to just take it to a GM mechanic. They diagnoised it as a bad distributor cap and rotor button. They said it was missfiring on #3 and #7 cylinders.
After the van was fixed the check engine light was kicking on.
So is a PO420 code in relation to the sensors before the converter or after? I'm getting allot of conflicting information on this PO420 code. Someone said if you get a PO420 code pertains to one of the sensors before the converter.
If the sensor after the converter reads the same as the front sensors, then it throws up a different code.
I wouldn't think a bad converter would cause an engine to run rich. It was my assumption this sensor just checked the performance of the converter. The front two sensors was what monitored the engine efficiency.
I talked to a guy I work with who has a 90s Chevy truck V6 and he says his converter went bad and was causing bad fuel economy but he says it was throwing a "cat converter" code. He recommended taking it to a muffler shop I've frequented in the past who can actually test the converter.
The misfire probably melted your cat. The code will keep re-appearing until the cat is replaced - that's the way they designed it. Upstream o2 sensors have no bearing on the code. The code is thrown when the post-cat o2 sensors voltage begins to vary, much like the 2 sensors before the cat. With a functioning cat, the voltage should be steady, with no variation. When the voltage begins to vary due to unburnt fuel in the exhaust, it throws a P0420.
I agree with Fred, but doing that all depends on where you live. Here in the republic of MA, if the check engine light is on, or if you clear the codes & the monitors have not run & you try to get an inspection sticker, you fail .... then you get harassed by the cops who essentially have become "hidden tax collectors" for a state that cannot control it's spending. :lol: It's all politics. I had asthma before they required cats on all vehicles .... and I still have asthma with all the "feel-good" environmental laws pertaining to motor vehicles in place. Just another way to unnecessarily extort money out of you .
Well a new converter will for itself in fuel consumption if that's the problem. Just like that day I borrowed dad's truck to take some bumpers to get rechromed which was 30 miles from my house. I knew the thermostat was not stuck open so I took a blanket with me. By the time I got home I had used over half a tank of gas. I figured I was getting 4 mpg. A new thermostat would have paid for itself from that trip alone.
If the conveter has melted/collapsed then looks like the van would run like it's got a potato shoved into the exhaust. It seems to run fine otherwise.
There is no inspection system where I live. Dad asked if I could gut the converter but I don't know if that would fix the fuel consumption issue. Or by OBD II's design is poor fuel consumption just a way to getting your attention to swap out a new converter when it goes bad?
You have to fix the rich condition first .... unless you own stock in a cat manufacturing company. :lol:
If the misfire/rich condition is not fixed, you'll have another P0420 .... and you'll have just flushed a few hundred large down the toilet.
Have you check for a vac leak. If there is a vac leak the computer will increase the amount of fuel to correct the lean condition. I would start looking on the side where you had misfires on cyl. 3 and 7. Also your temp should be around 212º . Most car makers like their engine to run above 212º . The reason for that is so any moisture in the engine turns into a vapor and is cycled thru the engine via the PVC system. If the engine runs cooler than that the moisture will cause a sludge build up inside the engine. That being said the temp gage might not be accurate. If you find that the gage is accurate then install a new thermostat.
    CaptainDad
    CaptainDad
  • Who's Online   1 Member, 0 Anonymous, 569 Guests (See full list)
