4wd Not Working
hey guys i have a 1990 1500 and i have no 4wd any more. i put a transfer case from a 95 in it and now i dont have 4wd any more. i pulled the actuator on the front diff and when i turn the key on it comes out. turn key off it goes back in. i believe the transfer case is working, when i put it in 4 low it feels like 4 low. dont know what else to do.
