Door Hinge Weld
My drivers side door on my truck has sagged a little lately, but I always figured I would just have to tighten something up to fix it. I took a look at it this morning and it appears that there is a crack where the hing is welded to the cab. I would assume that that needs to get fixed pretty soon. I guess my question is how much will it cost me? and maybe where can I go to get it fixed.
I would assume that any reputable welding shop could fix it up for you. I would also not just weld over the crack, I would position it where it needs to be then weld it back up.
How much would you expect to pay for a job like that? I can put up a picture in a couple of hours. It doesnt seem that bad, i just dont want it getting worse.
Tooooo many variables. 50 bucks to 400 bucks depending on what cause the bond to break in the first place.... Weak metal behind or what........
Also, make sure they use welding blankets..... Plastic, carpet, and your patients will be tested if they don't.
Jbo
yep, blankets for sure, those globules of molten metal will wreck anything plastic or fabric they land on. And yeah, make sure the door is placed back into position.
Here are some pictures, looks like a crack in the welding and there is a small dent by the latch of my door, i think it might be from the leaning of the door
Your not using it as a crutch are you????? I see that a lot toooooo.....
Do you pull the handle push the door out of the way, let go get out and slam? and Pull Handle and door open let go, get in, and then grab the handle and slam closed???? or do yo find yourself always holding the door to get in or/and out?
But I have had to weld hinges back on vehicles.... But most of the time I had to add metal from the inside (behind the dash in the post)...
Jbo
No I dont use it as a crutch. I just bought the truck in the summer, so it is very possible that the previous owner did. I have no warranty or anything though. I shut it gently. So you think that will need to get fixed? Could anything else cause that? And how much would getting it replaced cost?
Ya you might wannnnna get that fixed asap,.... I have seen doors that fell off... Because of neglect of hinge problems.....
Jbo
    Brendan C
    Brendan C
  • Who's Online   4 Members, 0 Anonymous, 1,220 Guests (See full list)
