Squeaky Squeaky ?
2004 GMC Sierra 2500 HD 8.1 engine only 55,000 miles.
Last year the dealer did some laser alignment procedure to the pulleys to make sure they were aligned. They also put a new serpentine belt. The squeak stopped.
A few months later it started squeaking again. I had the dealer check the pulley alignment again and they said it didn't need adjustment. They put some of the 3m belt paste on there and the squeaking stopped temporarily.
I have put up with the squeak for about 5,000 miles. I have been putting on the 3m belt paste and it won't stop squeaking.
So today I said I'll just put a new Dayco serpentine belt to see if that will stop the squeak. When I had the belt off today I spun the alternator pulley and it squeaked. So I replaced the alternator today along with a new serpentine belt. I clean up the pulleys too. Guess what? There is still a squeak. #$%#$%#$
So now also today I replaced the belt tensioner pulley in case that was it. Nope. Still squeaks.
What do I need to do or check now????
Thanks.
Jeff Fox
when the car is running use a big flat head screw driver and press against all the pulleys to see if the noise changes. then youll know which one to replace
first you need to figure out if it is chirp or squeak. Chirp is caused by misaligned pulleys, squeak from a bad bearing. If it is chirp a light squirt of water on the belt will make it stop for a short while. If it is a pulley I have had luck by giving them a shot of wd40 and to see which one it is.
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 910 Guests (See full list)
