Awesome F-Body Video...
Zane
Great clip those guys should do commercials for GM.. How many sets of tires did they go through making that?  you could almost smell the nitrus.. well at least see the evidence of the blow out valve.
Have you guys ever checked out the video of TBYRNE's project camaro? I knew it would be fast but when I watched the clip I actually said "Holy S#!&" out load! It wasn't until the third time I watched it that I realized there is a Mustang in the other lane.  :D
I can only dream my car will run like that some day.  :D
Tommy likey....but you guys need to remember The Fast and The Furious those cars have real power...fill'em up with uncle Ben's fried rice and watch all 1.8 liters of domestic crushing motor featuring 200hp/93lbs/ft. torque eat those F-Bodies.... :jester:
