My Sierra Runs Poorly When Cold
levi2009
Hi All, I've been a member since 09 and have always been able to get answers by searching, but today...no luck.
I have a 1999 Sierra half ton 4x4 5.3cid w/4L60E and electronic 4wd, and this is what's going on, when I start the truck it starts & idles fine, if I start driving immediately it hesitates severely on acceleration and will do so for the first 4 or 5 minutes then it will accelerate & drive fine, if I stop and shut off the engine for even 10 seconds the hesitation is back. Also if I start the engine and let it warm up for 5 minutes it accelerates fine and all is good.I have replaced the Fuel & air filters, spark plugs and cleaned the throttle body and nothing has changed.What should I check next?
Please help me out guys.
Thanks,Levi
WE LIVE IN THE LAND OF THE FREE, ONLY BECAUSE OF THE BRAVE!
Thanks,Levi
I didn't know a 99 K1500 had a 5.3. The only engines that I knew were 5.0 and the 5.7.
Hard to say what the problem is but I had a truck once that acted this way and it turned out to be a bad 02 sensor.
    rayredbone
    rayredbone
  • Who's Online   1 Member, 0 Anonymous, 525 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
