96 454 Falls Flat When Warm
GaryRoe
1996 3500 single wheel pick up, automatic 454.
Truck runs great cold, but when it warms up, will idle only. Only code showed was MAS AIR, so I replaced it, and the fuel filter. Unhooked the battery. Now, no codes but does the same thing. Gonna test fuel pressure hot and cold tonight...what else?
Thanks in advance.
I had an 00 siverado 454... same vortec motor.
Sounds like when it gets warm somethings pulling timing and/or fuel out of it..My 01 350 van was doing very funny intermitent things, and it ends up being the computer or "pcm"
Very hard to diagnos..we had low fuel pressure at 1st and waisted 300 bucks on a new delphi fuel pump. Have someone with a decent scanner like snap-on modis, check it and start flollowing wires.
    rayredbone
    rayredbone
  • Who's Online   3 Members, 0 Anonymous, 280 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
