Fuel Injectors
turboherb
as in remove them then clean or leave in and drive with cleaning happening?
most gas now a days has enough cleaning agents in it to make dirty injectors a thing of the past...but seamfoam,GM's fuel system treatment or chevron are all good dump in the tank kind of injector cleaner thingy ma bobbers
thanks a bunch,i just wanted something to throw in the tank.have a day!!!!!!!!!!!!!!!!
I have used the Chevron Techron cleaner and had good results. I use Lucas fuel injector cleaner right currently and it works fine also. Chevron works best when your normal gas is not Chevron (since you get it already if you use Chevron gas).
    rayredbone
    rayredbone
  • Who's Online   1 Member, 0 Anonymous, 475 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
