Tires/levelling Kit
I have a 2005 Chevy Silv K1500 Crew Cab. I'm looking for advice on two things. A: considering switching from stock 265/70/17 to 285/70/17's and want to know if anyone has had any adverse things occur from doing this (excluding speedometer and less torque) B: am interested in a front end levelling kit and have no clue which is the best with the least amount of modifications. Also, any adverse affects from putting a levelling kit on my truck??? Thanks!
Just crank your torsion bars to level it. It will ride alittle more stiff.
285s are not large tires you will be fine.
You will need to get an alignment after doing any adjustment to torsion bars, most places charge around $50 for this. 285's will go with no issues. I am running 295/70-17's (have been with stock torsion keys for months), just last week put new keys on and i have easy clearance for 305's.
Good info, which brand torsion keys did you go with? Did you put them on yourself or have someone do it for you? Hard to do for a somewhat mechanically inclined person?
    President Roberto
    President Roberto
  • Who's Online   2 Members, 0 Anonymous, 874 Guests (See full list)
