Should I have the integrated brake controller
I recently used the Comp-nine decoder to see what all came on my truck. I was looking through it and noticed that I had the JL4 Active Brake Controller option. Is this the option for the integrated trailer brake controller?
If it is, does that mean that I should have the option or does it just mean that I have all the necessary hookups and provisions but just don't have the switch?
Nope,thats not the brake controller option,thats the Stabilitrak system.
Option code JL1 is the brake controller option.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
