2002 silverado heating problems
I need some help. I have a 02 silverado that the heater doesn't heat. I have changed the thermostat and the blend door accuator. The next step I guess is to replace the heater core. My question is, is this right and how difficult will this be? Any help will help. How do I get to the heater core how much do they cost? Thanks for any information.
Changing the core is a lot of work. You basically remove the whole dash. Have you tried flushing the core?
With the truck at normal operating temps (195-210) does both the heater hoses get hot or just one?
As suggested above, try flushing the heater core first. Remove both plastic fittings from the heater core and try flushing the heater core out. One fitting has a restrictor, so you will get more volume in the heater core by removing the plastic fittings.
The heater core is cheep in comparison to the labor it will require to put it in the truck. Unless your just happy buying it and riding it around in the floor board or seat...... This is an under taking to change. Drop the steering column and remove dash, place on ground out side the truck. Then your in business.
Jbo
    Brendan C
    Brendan C
  • Who's Online   1 Member, 0 Anonymous, 1,130 Guests (See full list)
