Steering gear box
2001 Z71 5.3 with 150,000 miles.
My power steering started making a weird noise yesterday as I pulled out to go to the hunting land. I quickly pulled back in to the driveway and parked it. When the sun came up I checked the fluid level and the resevoir was empty. I got it to my mechanic and he says the steering gear box was leaking. He quoted me 500.00 for the repair. Needless to say, I filled with more fluid and drove it back home for the tme being.
How hard of a job is this to do? Is it something I could do myself or better off leaving it to someone who does this for a living? What parts do I need to research for the best price and is there a "steering box" that is better to use than others? Does his price sound about right for this job?
Any help is greatly appreciated for money is tight taking it is Christmas time.
Thanks in advance for any help!
I replaced my steering box on my 93 2 wheel drive Sierra. I can tell you it wasn't fun but I was successful. I needed a front end alignment when I was finished. Even though I kept the steering wheel straight it was 45 degrees off when the wheels were straight. I posted about it some where on this board. And the shop I think wanted closer to $700 to do the steering box so I did it myself. The steering box cost me $200 or $250 so $500 to install it on yours doesn't sound bad to me. You'll need a puller for the pitman arm I think. I don't know how different a 2001 is from a 93 and mine was 2 wheel drive. Good luck.
It's not that simple of a job. You probably burned out the steering gear box with the lost fluid. So now you need a new gear box. The system needs to filled with fluid again and bled. You cant mess around with the steering which is serious like brakes. If you are mechanically inclined and have the service manual you could do this. Still though a new gear box is like $250 right there. Then you have to rent the puller to pull off the pittman arm. I would pay the money, steering is not one of those things you can do half ass. If you are going to do it as I will be doing mine only because I want to keep my truck like forever. I would get an agr steering box from summit auto. Put on a new pittman arm and replace the intermediate shaft at the same time. My Truck is 1998 Z71. Anyway Good Luck
Appreciate the replies. He stated he saw where I had a leak on the box. He also said he has heard of people "resealing" the box at some places. Im sure I will be letting him do the job. He said I could get the part myself for cheaper than he could. Im not needing anything special I dont guess. He said most of the parts stores around town will only have the reman part anyways. Im just wondering if there is a paticular parts store or brand I should stay away from. Looks like it will run 200-230.00. I do plan on keeping this truck forever which I have already had it for many years. I dont want to use any junk part for I dont want to have to pay him to re-do again just a few months down the road
It is not that bad, to change the Steering gear. Unless you live in a salt band area. And you should not need an alignment afterwards. Note the position of the pitman arm prior to removing arm, replace in the same spot. However you should only be able to push the arm on in one spot and it line up with the grooves........
You will need a pitman arm puller. And socket large enough for the nut as well as a ratchet. Don't forget to soak it several times in penetrating oil several times prior to starting (ie spray if for a couple days, if it is bad rusty)
Happy bleeding of the power steering system.
Jbo
wheels off the ground and engine off,turn wheels stop to stop several times to bleed it ....
and repairing the leak is easier than replacing the gear,they sell seals for it,
where is the leak coming from ? input or output seals?? is it the line above the box flowing onto the pump???
Im not sure exactly where it is leaking.My mechanic just said the gear box is leaking.Wouldnt you have to remove the box to replace the seals?Liek I mentioned,he said he has heard of some people just replacing seals but he wasnt really sure who around my town would do it.He metioned the dealer may do it.My concern with them is the cost.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
