Modern Firearms Show @ Big E (MA)
Magic Wheels
Dec 10, 2011 - Dec 11, 2011
Better Living Center
@ Big E
1305 Memorial Avenue (Rte. 147)
West Springfield, MA 01089
:M16::M16::M16:
    contrabombarde
    contrabombarde
  • Who's Online   2 Members, 0 Anonymous, 1,150 Guests (See full list)
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
