Leveling Kit & Wheel Offset
TheHilltopHood
Hi to everyone, I just traded in my JK Rubicon for a silver '08 extended cab silverado. I'm loving the truck so far.
I know this topic has been discussed over and over, but I couldn't find any information regarding different wheel offsets. I plan to do a 2" leveling kit in the front as well as one inch bigger blocks in the rear, and will be running 285/70/R17 Duratracs... which is the largest recommended size, correct?
Anyways, I'd like to get some aftermarket 17's that "stick out" a bit farther than stock... As much as possible without rubbing. Some offsets that I'm considering:
+ 31mm (stock, will not rub)
+ 25mm (I don't think this will rub)
+ 18mm (might require a little trimming)
+ 0mm (this requires trimming both the fender and some metal, from what I've read)
So, for everyone running a 285/70 tire on a 17" rim (or an equivalent tire size), post up your offset and whether or not you had to trim your fender. Any info is appreciated, thanks!
I can tell you on a 4x4 with stock tires on a 17x8 aftermarket rims with a 0 offset. I can get my tires to rub in reverse going upgrade while turning. When I had my 2008 I had 285x70x17's on a 17x8 0 offset. I had to raise the front 4" for it not to rub at all. I had 1.5" body lift and a 2.5 leveling kit. I hope this helps..
Personally if I was buying new wheels I wouldn't want anything more than +18. Aftermarket wheels with no dish look like crap to me. If you feel comfortable trimming then get 0 offset it will look the best.
My wheels are +25 offset, and my 285's just barely rub my mud flaps when I'm backing up with the wheels turned. Without mud flaps, I don't think they would rub.
I tried to post a link, but it's not working. Use the advanced search option and search for "New Tires & Wheels Installed" as a topic title....it's the thread I started when I first put my lift, wheels, and tires on my truck.
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 1,032 Guests (See full list)
