WTB: Heated Windshield Washer Bracket
Combat_Vet
I'm interested in purchasing the GM OEM Bracket for the Heated Windshield Washer module for a 2009 GMC Sierra or Chevrolet Silverado from someone affected by the recall in which the dealer had removed their module under that campaign:
Full Details on the recall:
http://nhthqnwws112....10V240-4402.pdf
The GM RPO code of affected vehicles is XA7
I would like to purchase your bracket which is mounted on the firewall on the drivers side under the curved shaped fender support.
Or if someone would prefer to remove theirs and send it to me temporarily, so I may fabricated an identical copy, I'd be willing to pay for shipping both ways.
If you are going to install the Alpha-Therm heated windshield washer fluid and haven't ordered it yet, ask Joe. He might have one for you. I ordered mine two weeks ago and he said he had a few of them.
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
