Weird sound when truck is Cold....
Havent owned my truck through a winter yet so this may be a normal sound I am hearing.
2007; 5.3 AFM; 35,000 miles
I have no burning oil problems and no other problems to speak about. When I start the truck on a cold morning, (20-35 degrees) it starts right up without a problem. I warm the truck up and go on my way. When Im creaping through my neighborhood the sound that I get from the engine is like "Whirling" sound almost. Happens as the RPMS raise up, under 2000rpms.
Im very easy on the the truck all the time, especially when on cold mornings.
What do you guys think.
-matt
Is the noise coming through the speakers? I ask because when my iphone is pluged into the aux port but not playing music, it'll create the whirling sound.
Only other time I heard the whirl in the engine bay was with my old 98 grand am. Turned out to be the Power Steering pump.
It is the engine fan. In cold weather the fluid in the fan clutch thickens and takes a few minutes to respond to the thermosstatic element. Just turn up the radio and enjoy the ride.
Ken
Ken
GM went to electric fans in 2006....
Actually what you are probably hearing is the cold air getting sucked through the air intake. The vehicle is trying to get more air so it get actually get more gas to try and heat the engine up faster. The reason you don't hear this as much when you stomp on it at high speeds is simply because the engine roar and other things become louder then the air intake at those speeds. However at low speeds it is quite easy to hear it. I live up in Canada with -30 to -45 Celsius (-49 Fahrenheit) winters. Be happy that's all you hear from your truck, not the cracking, whining, clunking and other terrible sounds we hear through winter.
Makes sense.
I heard it again today..truck sat all night, 34 degrees when I started the truck. Whirling sound while it accelerates. Gone within 2 or 3 miles. Almost sounds like metal on metal whirling...
-matt
    CaptainDad
    CaptainDad
  • Who's Online   4 Members, 0 Anonymous, 585 Guests (See full list)
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
