onstar removal
hey guys does anyone know what the best procedure is for removing the onstar mirror in my 2011 silverado??
im not worried about people listening in on me or anything. i just dont like rear view mirrors. my last 2 trucks i took the mirrors off and this one is buggin me more and more everytime i drive it.
id think it be fine to just unplug it and jam it back in the headliner. im wondering if there is any fuses i need to pull or whatnot.
thanks,
You can probably just unplug it, the only error light there is to the best of my knowledge is the one on the mirror itself and if it isn't there then it can't really turn on now can it? :lol:
    Fishboat
    Fishboat
  • Who's Online   2 Members, 0 Anonymous, 516 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
