X-Mas hit and almost run
05 Chevdmax
you took my comment too harsh...i do realise that their is alot of people that do need the spots, but like alot of things in american society people find ways to use and abuse them(thus the chain smoker/obese comment)..i do not make a habit of parking in handicap parking, its mostly if i'm in a bind and need to be in and out quickly..now i apologize for coming off as an ignorant ass but you need to also step back and see my point of view..i know of people that are fully capable of walking across a parking lot and choose to use their grandma's or handicapped relative's parking pass(its a thingy you stick on the rear view mirror here)..it brings in the why should they get special treatment argument if their are fully healthy, but i also realise its damn dear impossible to tell whos in need and who isen't at any given time in a parking lot without getting out and playing 20 questions with them..i will admit i was partially wrong but not every person that uses handicap parking needs it...
Clearly, you either understand that it's illegal parking, or you don't understand. You can try to justify it however you feel it suits your needs. Just because some people choose to take advantage of the system, does not make it OK for others to do it. I won't be wasting anymore of my time trying to get through to you, it's obviously pointless.
just a little food for thought, speeding is illegal too even 5 over...having your truck lifted is illegal to a certain extent, having bald tires is illegal..not mowing your lawn is illegal...yet people break them, so please don't pound your chest at me like you got a halo above your head we all break laws, if nobody did it would be utopia and we would all ride unicorns to work
I'm sorry that I ever responded to your post. I should have known better. Please except my apology and let's move on.
  • Replies 31
Clearly, you either understand that it's illegal parking, or you don't understand. You can try to justify it however you feel it suits your needs. Just because some people choose to take advantage of the system, does not make it OK for others to do it. I won't be wasting anymore of my time trying to get through to you, it's obviously pointless. just a little food for thought, speeding is illegal too even 5 over...having your truck lifted is illegal to a certain extent, having bald tires is illegal..not mowing your lawn is illegal...yet people break them, so please don't pound your chest at me like you got a halo above your head we all break laws, if nobody did it would be utopia and we would all ride unicorns to work I'm sorry that I ever responded to your post. I should have known better. Please except my apology and let's move on.
yeah i agree lol
    rayredbone
    rayredbone
  • Who's Online   0 Members, 0 Anonymous, 506 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
