clean corner install
Hey guys.  I am new here but i am glad to be apart of a good forum.  My question is about the installation of the APC clear corners i just got for my 2000 Tahoe.  Its the old body style that they made right before the new one.  I think i have to take off the bottom turn signal lights and then the rest of the grille.  Is this correct?  If anyone can help i will be very appreciative!
you can either pop the headlights out  or pop the grill off     the grill is held on by one bolt, 4 turn snaps, and 2 metal snaps on each end.
the headlights should just come out when you remove the metal bar out of each side that looks like an upside down L
ok i took out my turn signal (lower light) and was lookin at how the corners were held in.  It looks like u just unscrew 2 things and the corners would come out.  Is this right?  I would rather not have to take off the grille cause i would have to to take off my brushgaurd too.  Thanks for the help!
You are correct, all you need to do is remove those two little nuts.  It might be alittle hard with the grille installed.  I had a '95 Tahoe, with a 3" body lift, and when I installed my brush guard, I made a custom bracket where I could pull 2 pins, and the guard would tilt down, Made it very easy to clean, and do installs like what your doing.  Hope I helped...
