Amp Wiring
Texas Z
This weekend I plan on added an amp and sub to my truck.  Where is the best place to hook the main power wire to?  There is a little red box under the hood that has a positive on it.  Can I put a loop connector on my power wire and hook it to that?  Also where is the best place to hook the secondary power wire to (the one that turns it the amp on)?
I have a factory head unit so can I hook the secondary wire to a fuse, like the windshield wipers or something that comes on when the truck is turned on?
Thanks for your help.
That little red box is there just for that reason since there really isn't that much room to hook anything up to th battery.  And run your remote wire to a switched fuse in the fuse box. I think I put a female spade connector on the end of my wire and plugged it in to a switched power in the lower right hand corner of the little black box on the floor.  Then you'll be ready to rock. :wtf:
Ok!  Who runs what subs here and how many!  I have 2 new JL 10W6's I acquired and am wodnering if that will be alright for the noise I want.  OR should I just run one of them??  This stereo stuff is new to me!
Man, be careful prodding around with a test light!  You really should use a digital VOM if ya got one. (volt-ohm meter)
-Thanx
I am adding a 8" bass tube that I had in my reg cab truck.  It made a huge difference in that truck so I am hoping it does the same in this truck.  I don't want a lot of bass just something more than stock.  Hank Williams Jr. sounds good with a little thump.  I don't know how much noise you want, but 2 tens should do the trick.  They take up alot of space.  I had my 8" bass tube in my reg cab and it made my truck shake, rattle and roll.
I had 2 12s in my old burb, boy did it make that thing shake.  Never bought or made a box for them until now so they will be rocking in the silverado as soon as the box arrives....I CAN"T WAIT.  Looks like I need to ask for some Dynomat for xmas! :wtf:
silverado man, what kind of speaker box do you have ported or sealed and how much room does it take up under your seat?
I just went to the local BrandsMart and bought one of there genaric boxes for $40.  Its a sealed box and fits perfect in between the trany hump and the wall, and flush with the front of the seat with about a 2" gap from the bottom of the seat.
    nolankd
    nolankd
  • Who's Online   2 Members, 1 Anonymous, 438 Guests (See full list)
    • For a limited time, retail accounts receive a free fender cover (G2803) with their order of $750 or more when they use code FENDER926 at checkout. The promotion runs through Sept. 8, 2026. Own a business and want to apply for a retail account?  Apply here. https://www.amsoil.com/business-opportunities/sell-in-your-store/?zo=521390
    • Thanks for that, yes just because I could I measured what came out just to give me some guidance although I already knew to expect it to take at least 9.5 to just throwing in the whole 10 quarts off the shot and doing a one and done heat cycle to drop out the excess to get to the proper level. I don't recall exactly now what I measured that came out but was less than I put back in, I knew I spilled some on the garage floor but the main part was that I was thrilled in the discovery I did not have to touch my exhaust to flex it down. The gasket manipulating is a pain of course to create that clearance to take the pan out and put back in but its all very doable if one is careful and not forcing the gasket to flex too much. From the quote I got at a transmission shop of 900.00 here in Canada ( never asked at the dealer what they charge ) I saved 700.00 doing it myself after paying for the supplies so that to me paid very good wages !, and I knew what fluid was put in and that I had changed the filter and that the level is correct without any doubts.
    • I do have one of the AFM diasable box, using it for last 1.5 years.
    • I found a setup that lets me open the cover partway with racks installed, using side-rail-mounted systems for easy access.
    • Typically its said and I agree so far that the engine oil drain plug oring is not required to be changed out unless you see some damage happening to the oring as apparently the oring lasts well. The dealer I have been getting a few parts from never even stocked the oring but instead stocked the whole drain plug that comes with a new oring which for the dealer is easier because they just throw in a new drain plug if there was any question about damage on it as well and charge the customer accordingly but again only if it is needed.    Also a hint about the drain plug oring to help it last vs a risk of causing damage to it, after its been removed and wiped off or washed off ( that is a whole other topic about some solvents damaging orings because some solvent types do ) to make sure to relube the oring with a bit of new oil so that it won't "grip" on the sealing surface of the pan and needlessly stress out the oring. Its no different than putting some oil on the sealing ring of the engine oil filter. So I just grabbed a new drain plug to have on hand although more recently bought just the oring as well but as its special it costs half the price of the drain plug ... !   Since you mentioned the hate to be empty handed theme, I am not sure what you have in the way of filter removal tools as I like using the exact sized for the filter steel 1" wide band with side to side swivel handle filter removal tool, and it can be used to snug up the filter without risk of damaging a filter as well ( its probably a lisle brand I have ). The drain plug hex size is 15mm and I always like using a 6 point socket if I have a choice and with this truck I've been using just a 3/8 ratchet that has a fairly long handle. Do you have a funnel that will work to pour oil in as that is definitely the short coming bastard part about the design with that fill port on the valve cover on such an angle that no normal funnel will even work. There are adapters and things on the market that will set into or screw into that fill port, I didn't want to deal with US shipping as that is all I was seeing at the time so caved and bought a Lisle brand multi vehicle fit adapter funnel kit and it really works well but there are much less expensive adapters out there that work in conjunction with an off the shelf funnel that would do the job also. Now that I have it, I like how it works and works so slick with the shape of the Amsoil 1 quart containers I have now switched over to. Whatever you do, have a funnel system of some sort as you will be swearing if you dropped the oil and then realize you have nothing to properly pour new oil in without spilling it all over the engine !.     Other comments, quite a bit of oil flows out down the filter when its cracked loose due to the housing above the filter so let it dribble down the filter until it slacks off flow and then remove the filter to create less possible mess. It seems these engines can sit for quite a while and drip and if you have time let it sit there and drip out of the engine as much as it wants. Also a good time to grease the 9 zerks on the front end, that's my typical practice anyway to grease the suspension and steering each time I change the oil. And remember to reset the oil change minder ( not something I am used to doing with older vehicles and equipment ).
