Electric fans
I've seen it done on a Sierra but couldn't find the owner to ask him about it.  Anyone know about putting in an electric fan in-place of the one attached to the engine?  I know you need one that produces 3000 CFM and it is better if it is placed on the inside of the radiator so it is pulling air through it rather than on the outside where it has to push air through.  If this is an affordable mod, I might just do it.  Anyone with any information?  Thanks in advance!
You can do it a few ways, there are kits available made to fit specific vehicles, just buy it and put it on. This would be the most expensive option.
   You can also buy individual fans and install them without a shroud or make your own shroud to fit, this would be less expensive than option one.
    You could also buy a fan/shroud set-up from a factory equipped car or van that is the appropriate size and make the modifications necessary to fit it to your truck. Twin fans are found on LS-1 equipped Z-28's, Firebirds, and turbo T-bird fans are a popular type also. These can be found at junk yards, many are offered on Ebay also. This will probably be less expensive than the first option also. It depends on your budget, how much time and effort you want to put in it, and  your level of creativity if you choose to get into a custom installation. The last two options will require wiring the fans as well and choosing the type of sensor and switches you want to use, option one will probably include the necessary parts to wire it.
From the "been there done that dept".
The Victim Vehicle: 1979 4WD Chevy Stubby.
I had stuffed a 400 small block in it and stuck on a set of Wrangler AT 32's (no lift kit).  I used this truck exclusively for towing a heavy boat and romping on the 'West end' of Dauphin Island Alabama.  When in that thick sand, my 4 row radiator wouldn't keep that sucker cool enough to suit me.
I snagged a set of fans off of a Subaru station wagon for about $25.  They fit PERFECTLY.  I just removed the old fan and bolted them to the frame around  the radiator.
They did the job VERY WELL:   BUT......I...not being wise enough or so motivated to engineer the thermostatically controlled switching system, relied on a much more crudely engineered deal.  The infamous toggle switch.
Overall...it worked very well for me, of course I knew when to turn em on etc...  But it was a holy pain anytime the wife drove the beast etc...
If you're gonna do it...ask yourself this question:
WHY?
CapnDean
    Brendan C
    Brendan C
  • Who's Online   6 Members, 1 Anonymous, 1,138 Guests (See full list)
