Says its an Evap Emission system leak.. then in parenthesis it says Gross leak/no flow.. any help or advice on this would be greatly appreciated. idk what they mean by evap system.
455 might just be a loose/defective gas cap. The evaporative emissions system is fairly complex, if you do some searching on google you can probably get a rough feel for what is going on.
thanx man.. i actually did what i should have done first and searched the topic and i figured it out.. i went outside and opened the fuel door and my gas cap was off.. i was like wtf cuz i havent got gas in a few days. but i did take my kids out riding around in the desert and it was bumpy as hell. so i think thats what happened. thanx again
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 950 Guests (See full list)
