Power Steering Pump Replacement
Hello all,
I'm going to be replacing the power steering pump on my '08 2500HD, hopefully this week, I once came across the removal/installation procedure that appeared to be from a GM tech and now I can't seem to find it (of course).
I'm pretty sure the users name was M.CUEVA and I've sent him a PM but not sure that he's still reading these forums.
I believe the thread also had the fan/shroud removal instructions as well although im hoping I can get the pump out with out having to remove all that.
Does anyone have these instructions or can send me the link to them?
OR have any tips / techniques on getting the pump out. I've got a puller and plan on taking the pulley off after removing the pump so as to avoid having to remove the fan and shroud.
Also wondering if there's a fool proof way of knowing whether the pump is shot or perhaps just the 'actuator/flow control valve' may be stuck.
(I had no fluid running from the booster when I tried to drain the system to change the fluid)
Thanks for reading.
Nick
