where to get 12v switchable power in '10 Sierra
I'm going to a portable XM receiver in my Sierra. It has a lighter style power cord. I was to tap into 12v somewhere behind the dash and install a lighter plug back there out of sight. I tried to tap into a couple fuses today, and either I wasn't get a good power connection or ground connection. Where is the easiest place to tap into 12v on these trucks that turns on and off with the key??
On the floor, next to the parking brake, there is a juntion block with a cover on it. Should have a few wiring harnesses plugged in, and still have some open slots for other connectors. I believe on the left side near the bottom one of the terminals in there is switched. Be sure to install an inline fuse!
I can use one of the "add a fuse" to get the power. Does anyone know which of the fuses is switched, or which fuse the radio is on? Finding a good ground under there is a pain too. I looked at some of the mounting bolts and they all have plastic around them.
Thanks 8.1, I will check that one out too!!
I tapped into the power wire for the 12v plugs. They are always on tho so I just have to turn off the Sirius when I'm not using it.
If you use the diagram below, keep in mind that the accessory pin (X14 pin 8) is rated at 2 amps ONLY - It WILL blow if you draw more than 2 amps!
If your accessory pulls more than that you MUST use a relay to switch a circuit with higher capacity.
If you can get your hands on a standard "Bosch" style relay, you can get up to a 25 amp draw from pin 5 by wiring it like this:
Terminal 85 - Ground (X14 pin 1)
Terminal 86 - Accessory (X14 pin 8)
Terminal 30 - Constant (X14 pin 5)
Terminal 87 - Out to your accessory's 12 v input wire
Thanks for the all info!!! I have a couple ideas for power, just need to look around and see where I'm going to mount everything.
    Whit.the.COB
    Whit.the.COB
  • Who's Online   3 Members, 0 Anonymous, 1,236 Guests (See full list)
    • Yep! This should be a pin somewhere as @pgamboa really dives into all of this. Thanks for reposting the link!
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
    • Atlas, you kill me As aggravating as a project like this can be you have been unable to hide your fascination with learning and using that angst against this beast like a Ninjitsu Master. It amuses you, admit it now.      BTW, love your writing style. 😉
