Tire size question
If I go to a larger tire from stock, like say 305/70/16, do I need to raise the truck any? If I don't will I get tire scrape?
I'm not going for a monster truck look really, just looking for a semi aggressive tire pattern and a tire big enough to fill up those large empty wheelwells. So I'm trying to decide between 305/70/16 or 285/75/16...thoughts?
Quibbs :cheers:
i didnt have to do anything with my truck to fit 285s
I didn't have to do anything to fit 285's either, but I think next time I will get 305's.  I haven't seen any pics of a 1500 (non HD) with 305's, but they should fit because the hight is the same as the 285 and just a little wider.  I'd like to see some pics though...
Well I think I am going to go with Nitto Terra Grappler AT tire. Semi aggressive tread pattern and good looks. The only question is, do I go with the 305/70/16 (12w/8.4side/32.8 tall) or 295/75R/16 (11.6w/8.7side/33.4tall)....
think I'm going to go with the 295's, they are almost as wide as the 305 but are taller, so they will take up more of the wheelwell  :thumb:
Now, where should I take them to be installed? Think a local Goodyear or Firestone dealer would do it for a fee?
Quibbs :cheers:
305's will touch a bit. A few cranks on the torsion. Trim the air dam and you will be ok. 4 1/2 to 4 5/8 backspacing helps.
This a 2500 LD isnt it?
My Truck
Nice looking truck you have there, that's the kind of looking Im going for....I hate to admit it, but I'm not very mechanically inclined. So when you talk about cutting and adjusting I get a wee bit nervous. I could learn to do it if someone who knew how was there to guide me but since there isn't I'll just probably go with the 285/75/16. Do you think the 295/75/16 would touch? I know a few that said they have 285's and those didnt touch.
2500 LD? 2500 (not HD) 6.0l with 4.10 rear
wider isnt always better.  Think about rock chips (even if you have mud flaps).  Wide tires = more contact with road = more things thrown at truck
Keeping in mind what Ryan said:  Wider tires sling more crap on your truck....  I still prefer the wider 70 series tire to the stock 75 series.  You can feel the difference when you first switch over to the wider tire.  And I LIKE that feeling!
Quibbs :cheers:
You think? I would sure hope a tire shop would install your tires for a fee. smilie_tannenbaum.gif
Just messin with u man. Let us know how it turns out.  :thumb:
Quibbs :cheers:
:uhoh: Believe it or not, a few years ago I took tires that I bought from a friend to a local tire shop, they refused to mount them because I did not buy the tires from their store  :(  I am going to order the 285's today, hope they make a big difference on look over the stock....I'll snap some shots of before and after once the tires come in and post them.
Quibbs :seeya:
    Brendan C
    Brendan C
  • Who's Online   3 Members, 1 Anonymous, 1,183 Guests (See full list)
