Dexcool
Anyone swapping out their dexcool for the green stuff. my mechanic recommended getting it out asap. if i do this will it void the 5yr 100k warrarranty. if i do this will I need to flush out the system really well?
Thoughts are appreciated.
Thanks
Ron
Nothing wrong with Dexcool. Leave it in. Change it every 2 or 3 years all will be fine. Every vehicle we have in our work fleet is running Dexcool and having ZERO problems. Vehicles as far back as 2001 with 200k miles
Your mechanic is running off of old information. Makes me wonder what else he's not keeping up on.
You would need to do a very thorough flush. And I could see a situation where your warranty for certain parts could become void, since only Dex is called for by GM
The biggest problem with what you have done, is mixing green (high silicate) with remnants of dexcool. There is a major compatabilty issue that can do much harm. The additive package, which only amount to about 4% by volume, is where the compatability problems arise.
It can be said that dexcool was a big mistake, but not because it is a porr coolant, but because of the backward compatability problems. The usual result from mixing them, is a precipitate, aka solids/sludge.
We have owned GMs since 1994 with Dexcool. Never a single issue and they were all kept for 9-15 years. Change it as recommended, never mix anything else in it and you will be fine.
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,179 Guests (See full list)
