Tailgate Adjustment
Sorry if this has been discussed already, but I need to know if a tailgate can be adjusted on a 2011 Silverado. When closed it does not line up correctly. It wouldn't be a big deal except I was installing a new bed cover and since its not "square" with the back of the truck, there is a nice gap on one side. Any suggestions?
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
