Wiper Relay
Where is the wiper relay on a 2003 GMC Yukon? I pulled every relay and the wipers still turn on. They are staying on and won't turn off so I figure it's a relay.
Thanks.
    Brendan C
    Brendan C
  • Who's Online   6 Members, 0 Anonymous, 1,086 Guests (See full list)
