First Seafoam treatment
anybody?
Well its pretty self explanatory, people on here can correct me if im wrong, but just put 1/3rd in the brake booster hose, 1.5oz per qrt of oil in the oil, and go ahead and put the rest or 1/3rd a can in the gas tank.
This is how I did it:
1. put in oil
2. put in gas
3. start truck and let warm to running temp
4. pull the brake booster hose and slowly dump SF in (have someone in the truck so not to kill the engine, also mine wanted to surge when I put it in so when it does that just put your thumb over the hose hole until it settles down.)
5. Once its all in the hose turn the truck off and let sit for bout 30 mins.
6. Start the truck and give it some throttle and enjoy the smoke show!
Just youtube seafoam, I remember seeing some good walk throughs on there if you need some videos.
Does that help?
anybody?
1. put in oil
2. put in gas
Does that help?
Oops i forgot to say that you should change your oil after about 50 miles or so!!!!
Another possible location would be the hose that runs from the back of the driver's side valve cover up to the top middle of the intake manifold. I would think that would get the Seafoam to the majority of the motor.
Please correct me if this would not be a suitable location to do this.
1. put in oil
2. put in gas
Does that help?
thanks. i guess my main question is which one is the brake booster? i think i know which one it is, but i want to make sure. sorry if i sound like a newb- but i dont like being unsure. i think its the hose in the top right corner
1. put in oil
2. put in gas
Does that help?
Yes that would be it. Your brake booster is right behind your master cylinder and the hose comes right out of the brake booster. When you pull that hose from the booster and start the truck there will be a vacuum
thanks for the help. im gonna try this soon.
I always go by the old rule, the best oil additive is no oil additive.
Strange; that seems to be my philosophy as well. GM seems to like it, too.
Well I changed the oil my car that had been seafoamed. I added 8 ounces to the engine oil and then sucked the other half of the can through the brake booster and ran the car 650 miles. I was planning on running the car 1,000 miles with the seafoam in the oil but the car was really starting to sound like crap and I had a very nice day yesterday to change the oil.
The oil came out blacker than I have ever seen it, looked pretty thin and watery too. I have one of the magnetic tipped oil drain bolts and the tip was covered in a dark gray sludge which almost looked like anti-seize compound. I am guessing this was a mixture of metal shavings and sludge. The oil filter in my car for this oil change interval was a purolator pure1 which looked pretty good but had a good coating of very fine, black grit on the media, which again, I had not seen before. Keep in mind I have been changing the oil in this car since 2004/30,000 miles and it now has 100,000 on it.
After the oil change was complete I lightly brushed off the dirt and re-oiled the k&N air filter this car has. I started the car and let it idle for a few minutes before backing it off the ramps. The engine sounded much, much better, being quieter and smoother. I checked the oil again it was still nice and yellow so I am guessing I got most of the old oil and contaminates out during the drain.
I was surprised how well the seafoam seemed to soften the sludge. In a relatively short time (650 miles) it seemed to remove quite a bit of garbage inside the engine. Nothing bad happened to the engine and it does seem to be running better now. All this being said, I recommend this treatment if you think your engine needs it. Seafoam has been out a long time and I don't think it would be so popular if it didnt work, go for it!
    B07
    B07
  • Who's Online   1 Member, 1 Anonymous, 871 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
