What do you do and why?
firecadet613
Well now that it's getting cold out, I thought I'd see what everyone does and why.  Do you let your truck idle up for a few minutes before you hop in and go?  I know a cold engine wears more, but is it really that much more?  My truck is garaged at night, and I normally start it up in the garage and let it run for a minute or two while I go back inside and brush my teeth/comb my hair.  After work though I go out and start it up about 5 minutes before I head home.  Only time I really just start it up and go right away is during the middle of the night when I'm going on a fire run.
So what do you do and why?
it depends on how cold it is. mostly i just let it idle long enough to let the oil circulate and then i'm off.
I let mine run for a couple of minutes befor I go, then I keep it under 2K RPMs untill it warms up to normal operating temp. I do not have an idle controller yet so I try not to let it idle longer then 10 minutes due to wet stacking concerns.
If it's below 20 degrees, I let my truck run a minute or so (just long enough to get the leather seat toasty).  Otherwise I just let it idle down ( about 10-15 seconds) and away I go...
Usually just let it run for 15-30 till she settles down a bit before pulling out in the morning, then kind of crawl up the street.  After work(3pm), I usually just jump in and go...sometimes the shift points will hold longer like we noted here before.
The only time I warm it up is when I have my 7 mo old son getting ready to ride with me.  Otherwise I just start it and go but take it easy on the gas pedal until the engine and trans temp guages are up to normal operating level-usually about 5 minutes.
This is a good thread by the way-lots of different answers.
In the X, my mom just hops in, turns the  key, and away  she goes every time.
My live-in aunt (long story) has a '95 (or so) 2 door Explorer.
She'll hop in, turn the key, and sit their for no less than 30 minutes before she goes.
I myself think it's unnecessary,but hey, that's just my inexperienced opinion.
I keep mine in the garage.  I back out VERY slowly (just roll out really) because it's a big truck and a small garage.  I wait until the garage door is all the way down and then drive off.  Probably 2-3 minutes until I step on the gas for the first time.
In the afternoon, I wait until the CSK goes away before putting it in gear and driving off.
I just let mine idle for a minute or two. I live in base housing and the speed limit is 15mph for another 2-3 minutes before I hit the big road.
Morning - Garage kept, I start it up and go after oil pressure comes up. Then take it easy up the hills in the neighborhood until I get to the main road in town.
After work (4:30pm) - If below freezing in the morning, I turn on the remote starter timer box (18 minutes) for 4:20pm. If it is not cold, I do the same as "morning".
Everywhere else in winter: Remote starter! My overall gas mileage is not good during winter, but it's nice to get in a warm vehicle when it's near 0 degrees!
Bob G.
I just fire up the Espar heater for 30-45 minutes before I want to go any where. This way the engine is up to 180 degrees on take off. Then take it slow driving off to help warm the drivetrain fluids. Instant heat and usually defrosted windows before getting in the truck.
Mine is garage kept so I usually start it up and let it run for a few seconds in the garage and then pull out and let it warm up for a minute or so before I leave. I have a pretty good climb as soon as I leave my driveway so I just like letting it warm up a minute or so before I start the mountain, winter and summer.
    • You won’t do better than stock exhaust without headers. Just put your favorite muffler on it and it will do the job.
    • I have seen different people in different places post different sizes of exhaust as stock for my 2014 Sierra L83. Some say 2.5 some say 2.75. I am considering replacing the muffler with a Dynomax Super Turbo, perhaps 17739.  I had the factory L83 5.3 replaced with another L83 5.3 from Jasper Engines. I also put new Walker Cat / Y pipe on. I would appreciate opinions suggestions about what would be a good muffler setup. My main interest is a low rumble and the best flow / fuel mileage I can get. Not interested in straight through glass packs or loud exhaust. Those days are way behind me now.  Thanks Guys.
    • Its coolant disguised as oil.   TSB 20-NA-166 -  20-NA-166 1..3   "To inspect for this concern, add coolant dye to the system, run the engine through warm up, pressurize the cooling system after warming the engine to operating temperature (let the engine cool overnight) and inspect the suspect cylinder with a borescope for coolant dye evidence. At times it may be necessary to remove the head for inspection. If the head casting line is the concern, the intake port will be wet with a coolant oil mix"     I'd say its the head, and its either leaking at the casting line and dripping down the intake into the cylinder, or its another spot on the casting itself at the cylinder that is getting wet.
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
    • Good information!  I didn't know about the dementia aspect and asked for a general for my second knee. I'd heard that recovery room time is usually shorter with a general.   The anesthesiologist talked me out of it and I had the spinal.  Inconvenience and/or discomfort is a small price to pay for reduced risk!
