HAPPY HOLIDAYS!
Hi 99Silveradoz71
When I bought the truck I didnt even care what the new design looked like. It was the guts of the machine I liked. Now when I see the truck from the front or the side I see one #### of a truck.
    Brendan C
    Brendan C
  • Who's Online   3 Members, 1 Anonymous, 1,035 Guests (See full list)
