Today is free listing day on Ebay!
bowtie_pasta
I'm sure some of you know about this.  Ebay sent an email to me last night with the details.  So I went ahead and put a video card I'm trying to sell up for auction.  Ebay waives the insertion fee (today only).  Pretty cool if you ask me.  :thumb:
later
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 290 Guests (See full list)
