sierra 8.1 exhaust
Im thinking of doing the no muffler route.....stainless long tubes, no cats, X-pipe, tailpipes out,..
Just hoping the backpressure isnt not enough causing the TQ to be affected..
It just depends of the size of the exhaust, but because of your engine it is hard to really go to big. What I would say for you is get lt headers with a 2.5 or 3 inch y pipe to a 3.5 inch exhaust maybe even a little bigger but it depends on what you want from the truck. If you want low end torque keep the exhaust small. If you want top end go bigger. If you tow a trailer a lot you might not like straight out the back because the noise will bounce off the trailer. Just my two cents.
you want little to no back pressure..what you want is a high viscosity of your exhaust gasses, and the ability to scavenge out your exhaust from the cylinders. on pipe size, going to big will cause the exhaust to slow down causing a "blockage" in the exhaust, slows down flow. to small of a pipe(s) will cause a restriction increasing back pressure. a H pipe or X pipe will help in the scavenging of your exhaust out of the cylinders during over lap of your cam..each exhaust pulse has a high and low area. the high side pushes the pulse in front of it, and the low side helps draws the next pulse with it from the next firing cylinder. on a V8 fires from opposing banks, so with straight pipes/dual mufflers there is no scavenging of the exhaust that can/will reduce the inefficiency of the motor..the feel of low end TQ loss. that's why a H or X pipe should be used..i have some texts on this somewhere on my PC, and will try to find it. this is what i could remember...if you research you will find that the auto exhaust is a very complex system..
good luck
man desrtrat that what i was looking for..a good explanation... like i said im still learning about scavenging/pulses
Im not some dumb you kid that just wants sound! I want the exhaust to be perfect and function properly..
the reason i emptied the cats was .i had a feeling there was sluggishness, and when i had the off the truck the were partially blocked, holding them up to the sun and trying to look thru. The truck ffeels great with the raylar cam and blackbear tune..the stainless works long tubes will really wake things up, Again i just want the exhaust to be 110%
Could you give me a call when you get a chance, Id really like to talk with you if possible for a few mminutes...
Thanks again (570)-656-2466.
sounds like an awesome setup IMO only thing I'd change is loose the x pipe and just true dual it the loss of torque will be so small you probably won't even notice it
Sent from my smartass iPhone using Tapatalk
    Greg3160
    Greg3160
  • Who's Online   1 Member, 0 Anonymous, 528 Guests (See full list)
    • Late reply, but yes—it works on the SLT trim. Compatibility comes down to the plastic shroud shape behind your mirror, not the trim badge itself. On the SLT with auto-dimming, it uses a plug-and-play Y-harness off the mirror/rain sensor power, so no need to run wires down to the OBD port. If anyone's ever unsure about fitment, just drop a photo of your mirror housing and we can double-check it.   Appreciate the detailed feedback on the install! On the windshield glare—we actually took feedback like yours and developed a dedicated CPL (polarizer) filter to cut down dash reflections on sunny days. If you're still running the cam, shoot me a DM. I'd be happy to send a CPL filter over for you to test out—no charge.
    • There are no stickers in your glovebox?
    • Look at the numbers on the stickers in the door jam...
    • Yes, every time the developer updates his code, you must recompile. I will private message you with the latest because it changes pretty much with every version.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
