OGM1 Backup Camera.. NEED HELP
Walt sent me a HU.. AWESOME. and AWESOME guy! Problem. I have a 2008 Suburban with factory BU camera. HOW DO I HOOK IT UP? All I see when searching is rear view mirror install help. mine showed on my factory nav..
thanks everyone!
ok Ive got it all back apart.. all I can find is those tapping the rear view mirror. WALT PLEASE HELP.. hahahaha I have a factory plug with three wires coming out of it that I believe is the wires I must tap but I am not 100% any input. the wire color are blue, pink, green.
I believe the rca shielded wire goes to blue and the ceter pin goes to white. Give walt a call, I was just on the phone with him not 30 minutes ago.
thanks everyone!
Last night I added a new schematic to the factory camera section on the OGM1 support page on the ADC Mobile site. This covers the connections when you remove the factory navigation unit and have the brown "X4" connector left over - this is where the factory camera wires are located...
I looked but I couldn't find any such page on the adcmobile site. Can you point me in the right direction?
Unfortunately, we need to protect the hard work that goes into supporting this product, so the OGM1 tech info page is password-protected and is only available to ADC Mobile customers.
However, the wires you need are the White (pin 6) and Lt. Blue (pin 7) in the brown connector. White is video positive and lt. blue is video negative. (The green/white in pin 5 is vehicle speed sense)
