Silverado performance
Hey I Wanted to do some performance to my 2000 scsb but don't wanna make it drag truck fast, I was curious on what I could do to my truck like cams, intake, exhaust, headers, programmer any ideas and particular brands that are better if you could help out it'd be greatly appreciated
Well you def just named most of what you can do lol. I'm getting a 220R cam from Texas Speed along with a 3000 stall Yank TC. Also getting LT headers with 14" magnaflows custom dumped before the axle. I already have a Black Bear Performance tune and you should definitely consider that on your high priority list.
What engine doe it have? 4.8 or 5.3? 6.0 swap would be a good, reliable way to acheive more power, but you'll have to either build your 4l60 or swap a 4l80 in there. Your choice, but by far the best mod I've done to mine is a 224 cam, and it'll benefit greatly from a 3200 stall.
Well, how much money are you willing to spend? I put a budget on "upgrades" for the truck to $2,500.00, I still have yet to break the 2k mark but I'm sure I will soon enough. The brands I am using are Texas Speed, Yank, Pace-setter, magnaflow, and a few others that are less performance related and more so just scheduled maintenance.
are you installing the cam and stall yourself or getting a shop to do it ?
Sent from my smartass iPhone using Tapatalk
Doing it all myself. I'm not sure if you remember a topic I made a month or two ago in the performance section, but I asked alot of questions being that this is my first time installing a cam, luckily my friend has a cherry picker so it should make easy work out of the install.
ls1tech has a good write up on installing a cam. Just take your time and double check everything before you start the truck
Yes and rotate the engine by hand at least twice before starting, just to be sure.
    rayredbone
    rayredbone
  • Who's Online   0 Members, 0 Anonymous, 510 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
