How to test wires
I wish to determine which wires are for what in my dashboard stereo area.
Among the wires, there are two yellows. According to the schematic, one is left rear speaker negative, one is switched from ignition. I am trying to test for power with a multimeter when the key is in the accessory position. I'm not getting anything. I need advice on the multimeter set up to read this DC amps.
Does anyone have a better way to figure out which wire is which?
First, set your multimeter to the closest setting, but not lower than, 12v DC. Touch the black (negative) probe to a paintless metal surface, then touch the red (positive) probe to the wire. If you've got the car on Accessory/Run you should see 12v from your switched wire.
a wiring diagram would be the best option in my opinion but the method stated above will work nicely if all you're looking for is power.
Thanks. I've tried that but I guess I'm messing up with the multimeter. Perhaps I'm not getting a good ground. I'll test it on a taillight or something I know.
Good idea. Always verify your test equipment is working and you know how to work it.
You said you needed to test amps. You want the meter set to volts like the previous posted said. If you already tried to test voltage with the meter set to amps (current) you may have blown a fuse in the meter and need to check that out. Could explain why your meter is working.
    Sothpaw27
    Sothpaw27
  • Who's Online   2 Members, 0 Anonymous, 446 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
