2009 2500HD Tire Size Change
Guest cecherry
Guest cecherry
I'm considering new tires for my 2009 Sierra 2500HD Crew Cab 4x4 Standard Bed. I would like to replace the original 265R70/17 tires with 265R75/17 tires to get the added load capacity. Will those work on my truck?
Taller side walls will not necessarily increase capacity. You are still restricted to the certified payload that is stated on the sticker inside the door. The tire rating itself will change dependent on type of tire (i.e. C, D, E-rated). Plus taller tires will throw off the speedometer and odometer and all that stuff. Why do need to increase your rating? If you just want a more stable ride while towing or hauling then stay with the OEM size and just get an increased rating tire.
Guest cecherry
I'm not trying to add extra load capacity to the truck, just looking for a little extra margin of safety. I haul a slide in truck camper that weighs 2200lbs. My current tires are E rated 3195 lb capacity. I thought I saw an E rated Michelin in 265R75/17 that had a load capacity slightly over 3400 lbs. I discovered this morning that I misread the specs and that was for a 16" tire. So far I haven't found a 17" tire to fit my truck with a capacity greater than 3195 which will work, just wanted that extra margin of safety that I thought I would get with a 3400+ lb tire capacity.
Thanks to everyone for their input.
Your current tires are rated for 3195lbs per tire. The 2200lb camper weight would be distributed among all 4 tires, not just one, so your safety margin has already been far exceeded. I'm not saying don't go for "extra" tire but you are already more than safe. I don't even have LT tires and mine would take that weight, just the truck itself wouldn't take it for long. I just don't want you to spend money when you may not necessarily need to. Now if you want new tires...go for it.
    • Yeah I don’t leave ANYTHING just sitting supposedly maintaining my battery on a vehicle or RV for multiday periods. I connect a charger as needed to provide a full charge, then disconnect it and either monitor the battery or follow a set schedule for periodic charging.
    • Get the 5.3. I`m not a Ford guy.😉   I think these L84`s are less problematic than the L83`s. Certainly less than the L87.
    • I have finally paid off my mortgage and can now purchase a new truck. I would greatly appreciate any opinions on the purchase of a new 2026 GMC Denali 5.3L or 6.2L with the Denali reserve package. I am not interested in the 3.0L.  Or should I go buy a Ford?   Thank, John
    • One of the few things I enjoyed about my time in the midwest was taking off on weekend drives. Unlike home, where we are boxed in by mountains and water, those rules don't apply to the inland plains. Roads connect and sprawl everywhere. While Minnesota is flat, it's not completely featureless and there are fast moving rural roads with curves and slight elevation changes. I used to relish heading out in a particular direction with no set destination, no curfew, and weaving through little townships, wherever the roads would take me. Along farms, lakes, or through the deciduous trees... It was beautiful in its own way, and the seasons were so distinct there. Fall drives yielded amazing shows of color and contrast. Summer drives rewarded with the and amber evening glow of the prairie (and lots of juicy bugs).    I do a lot of that here in my home state too. But it's much less mysterious/intriguing. I've traveled most roads in the region, and every road that's fun to drive within a good radius of my house. But every drive, even on the same old roads, is still enjoyable. I know where I can lean hard into the throttle or really throw the car into a curve. There are exercise loops for when I just need to keep certain cars limber, and much longer routes to settle in and enjoy a drive and put some miles on. All the mountains and water make for some really awesome roads for spirited driving. But not all my driving is spirited, for example, that's not really enjoyable in my pickup or this Blazer (that's still here...).   Sometimes a good drive is followed by a ritualistic wash before tucking the car away...
    • 'GMAuthority' is reporting the 2027 HD's will have the L8S 6.6L gasoline V-8.  There was some talk here about the L8S awhile back.  Not sure what changes it will have now as it seems the 2027 emissions regulations have changed from what was originally proposed.  The big question will be is L8S just a stopgap for the last 2 years of the current T1 HD platform or will it carry forward to the next generation 2029 T1-2 HD's?    I assume the L8S will still be a Gen. V engine.
