Email Virus Alert
Guest Friz
Attention!
I got the badtrans@mm worm virus to day. It was sent to GMTC email account from Bill Reynolds. Does anyone here know who he is. I replied to let him know that he's pumping this out, but the address that the email was sent from is no good. It was [email protected].
Bill, if you're out there, this is not a slam. I sent out an email virus a while back and didn't know it until I read about it here.
I don't understand why the return email was invalid, though. Any ideas from the computer geek network?
