Cleaning garage
Ok, so I am getting rid of some stuff. All of this stuff came out of my 2007 GMT 900 Sierra.
-Pioneer AVH-P4000DVD. $450
It comes complete with PAC wiring harness for NON on star vehicles. So, it is just plug and play. It also has the steering wheel control module and cables for ipod and a usb port that will play music or certain video files right from a flash drive.
-JL Audio stealthbox with sub. $300
This is a 10in sub that fits right under the center console. You can't even see that it is there! it is really pretty slick and sounds darn good. It isn't going to shake your truck apart or anything, but it does give a really good sound. I'm not 100% sure but I think that it will replace the bose sub in trucks with the premium sound.
http://www.jlaudio.c...uv-trucks-07-up
-Rockford 150s amp $50
This is an older amp that still works great. It actually works perfect with the stealthbox as there is a little compartment under the console that this fits perfect in. I only have one of the side plates as you'll be able to see in the picture, but if you use it with the Sub it won't matter.
-Boston GT20 amp $150
This is a two channel amp used to push a set of component speakers that are actually still in the truck. It fit very nicely inside the compartment in the center console.
If someone wanted all of the stereo stuff we could probably negotiate on the price of a package deal ;)
Peripheral electronics Ipod interface. The model is a PXDP. This is used to hook up to a factory stereo and allows you to play and control your ipod with your radio controls. I don't know exactly what applications this one works for, but can look them up. I used it in my 2001 silverado.
I was thinking $50
-I have an ECM/TCM set if anyone wants them. I don't know what they are going for and can't really remember what I paid for them. I think I just saw another set on here for $125ish, so if anyone wants another set that is what I will go with.
-Magnaflow cat back dual exhaust. Make me an offer...it has been used for like 2.5 years and sounds really nice. In fact when Justin at Black Bear tuned my truck he commented on how good it sounded. It is a stainless steel system though so it should be ok for an awfully long time. It is sized for an extended cab. Also, not sure i'm going to want to ship this one. I'm in SE MN if anyone wants to come take a look.
Lastly I have some bits and pieces from a Series 77 K&N intake system. I think I have everything except for the actual intake tube. so...the filter and shroud thing that replaces the airbox. Make an offer.
I am having trouble posting the rest of the pictures, I will keep working on them, but I could also email them to you if you are interested.
May be interested in the stealthbox, does it fit under the LT console without the bose set up?
Could you send me a picture of your center console. There are 2 different console inserts one has a deep front compartment the other is flatter. When I got the stealthbox I had to get the other console insert I had the wrong one. If I remember correctly it was like $45 from GM parts direct or some website like that.
My console has the deep front compartment. Do you happen to have the part number for that insert? Want to sell it with the Stealthbox or atleast have a picture of it?
  • 3 months later...
Hey everyone, I'm going to give this post a bump to the top. Still sitting on a bunch of stuff. Exhaust and ipod interface gone. Shoot me an offer.
Tony
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
