Gauges Inop
2012 Silverado LTZ, 6000 miles, jumped in the truck to run to the store, fired it up, no tach, speedo, oil psi, temp, or fuel gauges, DIC functions inop, voltage gauge was working. ABS light was on. Noted that turn signals etc worked and the other idiot lights went on (for the momentary bulb check) when I restarted it.
Took it to the store, went in, got my stuff, restarted truck, everything works.
Anyone had this on a 900 truck? Thinking the abs module at least would have logged a dtc.
Not all code readers read ABS codes. Many will read engine codes only.
Check battery cables. Check battery cable connections. Check body grounds
