Center Console Information Request
My truck is an 07 GMC Sierra Classic with the 5 speed manual tranmission and a bench seat. I am considering adding a center console unit and have been looking at two that will fit without interefering with shifting, The first is a Rugged Ridge Truck Bench Center Console (autoaccessories .com). The second is a Econo Bench Console (truckaddons.com). Both are mounted using the center seatbelt. What I'm looking for is does any member have experience in using these or similar types of units? Any ideas on what to do keep the front of these types of units from moving around if bumped? Lastly, does anyone have a source (besides ebay or local yards) for purchasing a center console seat?
Thanks in advance for the help.
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
