Electric fan swap!
I'm in the middle of swapping out a set of ported LQ9 heads on my 04 2500HD. I was also going to replace bunch of parts since winter is coming and I don't feel like doing it in -20 degree weather. I took off the fan and noticed how heavy it is and was planning on swapping it to a electric fan.
I had two 15" push fans laying around my garage from my previous project and was going to utilize them here.
As far as wiring them, I'm in ?????? I looked online and found a 190 degree GM temp switch with two lead coming from it. I assume this is a temp switch. I was thinking of wiring the ground straight to the frame and the 12V+ lead from a 12V ignition source to the switch and from switch to the fan.
If there is a electrician guru here can you help?
Thanks,
Dan
You can actually drive them with your PCM. It requires a reflash but someone like BlackBear can do that.
    250.3k
    Mgyselinckjr
    Mgyselinckjr
  • Who's Online   1 Member, 0 Anonymous, 371 Guests (See full list)
