2003 Sierra Z71 155k
absinthminded
I've got a 2003 Sierra 4x4 with 155k on the clock. About a month ago I replaced the driver"s side wheel bearing because the ABS was kicking every time I pressed the brakes. Now I have a new problem. I have a strange grinding sound coming from the front end. It happends at high ways speeds 40-80 only while turning left. The sound does increase/ decrease with changes in speed. I tried to replicate it in a parking lot with no success. I even put it in 4WH and tried full lock circles and got nothing.
It sounds like a grinding noise, not a clicking. I'm guessing its the passenger side wheel bearing. I looks like my seals are shot on the transfer case front diff. Its a bit damp where the half shafts connect.
Thanks in advance
By Transfer Case do you mean Differential? The transfer case in the 4WD gear box that mounts to the back of the transmission. The differential is what the CV shafts go into. Did you check the differential fluid level? If the differential has been run dry for a period of time it can make a grinding noise. Could also be the wheel bearing as you suggested.
Sorry, yes I ment front diff. I haven't checked the fluid level yet. My wife usually drives it and she said "its making a funny noise, you drive it." I will jack the front end up and shake the front wheel and check the diff fluid.
    Whit.the.COB
    Whit.the.COB
  • Who's Online   1 Member, 0 Anonymous, 1,254 Guests (See full list)
    • Yep! This should be a pin somewhere as @pgamboa really dives into all of this. Thanks for reposting the link!
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
    • Atlas, you kill me As aggravating as a project like this can be you have been unable to hide your fascination with learning and using that angst against this beast like a Ninjitsu Master. It amuses you, admit it now.      BTW, love your writing style. 😉
