Ground Bolt
I need help IDing the size of the ground bolt on a 2012 6.2. Its located on the passenger side front of the block. Its metric of some sort. I need the nut size so I can ground my winch.
Or just drill a new hole in frame horn and grind to metal. Bolt on ground, paint over to protect from rusting.
Ive done this in multiple spots on my truck for accesories / my compressors.
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,129 Guests (See full list)
