Comparing MPG
06tyler06
I've been looking around for a new truck. Had plenty of V8's, 88 Sub 350 2bbl tbi, 83 El Camino 350 4bbl carb, 77 C10 305 2bbl carb (had best MPG), and 04 Silverado LT 4.8L 4wd. Recently I've been looking at getting an S10 (94-2002). I noticed that most people report on average 16mpg for a v6 S10, when that is about what I get with any of my bigger motors. Then I see some 4 cylinder owners saying they get up to 30mpg with standard transmission. I'm just pretty confused on how such a small truck (S10 V6) gets the same MPG as my bigger, heavier, lifted Silverado V8?
My '89 S10 Blazer with a '00 4.3 carbureted engine gets 15-16 mpg -- same as my full-size extended cab truck. You'd think the smaller Blazer would be several points higher. Only a 3 mpg loss going to carb, but 100x more reliable now.
I guess the design of the 4.8 / 5.3 / 6.0 is more efficient, apparently.
How you drive, & where you live has alot to do with how high that number will go. I've got a heavy foot according to the wife, so I never hit anywhere close to those numbers.
The other factor, at least here in MA, is that they mix a LARGE percentage of ethanol in with the fuel - that kills fuel economy (and HP). It's posted 10% at the pump, but the reality is that it varies day to day, and station to station all the way up to and over 20%. I won't get into how big of a SCAM this is ....
    RichardRS
    RichardRS
  • Who's Online   1 Member, 0 Anonymous, 626 Guests (See full list)
    • Well that book won't sell many copies. Taking ones right foot off the loud pedal never gets applause. Funny really, It isn't that people don't know what to do...they just don't want to do it. But they will complain about it. About bad craftsmanship, about the cost of fuel, about the cost of part and repairs and mainly they complain that the solution while still possible isn't one they are willing to do.    I observe this daily. 'Gas cost to much!", they wail, while they mat it passing at 80+ mpg and scoot down the road like gas cost a dime a gallon. Then complain about the few that will lift and save both fuel and iron like they are owed and own the road.    Good thing they haven't an ounce of influence on my equipment. The rest I just laugh at. Stupid is as stupid does, right Forest?
    • Today I filled up with 4.899 gallons of fuel at a cost of $4.899 a gallon. $24 bucks. 290 miles. 59.2 mpg. After my 4% COSTCO discount just under eight cents a mile.
    • Howdy folks,   Recently I pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain (part numbers coming soon - will have to disassemble), and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash for the heating element.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But I seemingly can’t turn it off AND still no backlights on any of the buttons.    Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • I'm about 1800 miles into my last oil change, and yesterday a message appeared saying oil life was at 77%. Not sure why it popped up but I think all of these electronics could be susceptible to solar flares or somesuch. I change my oil right at 3K each time, and that was the first time in 10870 miles that message came up. Strange thing is that it showed on the screen at all since I don't drive with that sort of info displayed on the DIC.
    • I’m praying that someone sees this and can help me out… pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain, and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But can’t turn it off AND still no backlights.   Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
