What rims fit?
I'm wanting to start looking for rims for my 2005 1500HD 4x4. I currently have 285/75/16 Kumho At's on stock rims. I like the look of trucks that have their tires sticking just outstide of the fenders. Not like a 10" wide rim. I haven't decided if I want to go with 16" rims and put my current tires on it or step up to 17". Is this possible without a lift? Also, post what you have and pics are always welcome.
If you go with 17,s use a 285 70 17..same size as the 285 75 16.
If you go with a wheel wider then then oem 16x6.5 you might have a slight rub.. you can trim a little or adjust your torsion keys/bars to gain and 1" or so.
Honestly I would do a 2 or 3" block in the rear depending on how much higher you want the rear, Then do a new set of keys..adjust them were you want and get an alignment, you can get shock extension for like $29 and leave your factory front shocks..If you only go with a 2" block in the rear your oem rear shocks will be fine also,
Where would I need to get new keys, blocks, and shock extenders from? Is there a "kit" I can buy that has it all like from rough country or someone else?
I have a number to a guy ive been dealing with for yrs.. hes the best.. good pricing, fast shipping!
-Rich 'maxx lift' 1-803-600-2149 tell him Ron from pennslyvania told you to call!
He will have everything you need
-front keys W/ extensions
-rear block kit W/u-bolts
-new shocks if you want them...
If you have any questions or want to talk about it you can call me 570-656-2466
    appletrav
    appletrav
  • Who's Online   5 Members, 0 Anonymous, 501 Guests (See full list)
