need help with freeze frame
Crunchnmunch
i recently purchased a truck approx 5 months ago and it has been hell. its a 2003 gmc sierra k1500 v8 4.8L manual reg cab long box 137000km. i have a hole lot of problems with it, so far i have changed all the brake pads, calipers, rotors, brake lines also have replaced spark plug wires, plugs and changed 3 coil packs 1,5,6. iv been dealing with a random misfire code p0300,p1380. i had gm hook up a code reader and they said cylinder 1,5,6 were the worst thats y i replaced the packs but to no avail that didnt help. i purchased a code reader for my laptop and started looking at the freeze frame data but to be honest im pretty lost with it. this data if from a trip to my cottage and back 100km/h for approx 400km
just wondering if any one can look at my data and give me an idea of what i should try next.
sorry the program i use wont let me save the data so i had to printscreen and piece it together
The throttle position numbers don't look right. It could just be the instant the freeze frame was taken but I would get a scope on the TPS just to make sure.
I'll take off the plug and check what volts it's giving me
Any one else have any ideas or have ever incounterd those codes
You can't just take off the plug and measure the voltage. You have to probe the sweeper on the POT from the back side of the plug with it still connected. Do the test with KOEO and run a slow smooth sweep from 0-100% throttle using the pedal to actuate it. You really can't do it with a DMM. You really need an oscilloscope or a scanner with graphing capabilities.
ok ill ask my brother if his program can do that, he tunes cars for a living so im sure he can thanks in advance
did you go back and get your diagnosis money back after you changed the coils?
its THEIR fault it didnt work,
what was the labour for them to change the coils ?
    Whit.the.COB
    Whit.the.COB
  • Who's Online   2 Members, 0 Anonymous, 1,214 Guests (See full list)
    • Yep! This should be a pin somewhere as @pgamboa really dives into all of this. Thanks for reposting the link!
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
    • Atlas, you kill me As aggravating as a project like this can be you have been unable to hide your fascination with learning and using that angst against this beast like a Ninjitsu Master. It amuses you, admit it now.      BTW, love your writing style. 😉
