Lift kit opinions
I knew this day would come. I want a bigger lift..... So tell me Where is the best, cost, customer service place to purchase. Also I want to run 35" mickey atz's. I already have helo 835's so rims are covered. So what kit is best bang for buck? I do ocasionally go offroad but don't get too crazy.... Thanks!
If you want the best customer service and warranty, Hands down BDS without a doubt in my mind. If you want the most lift, Fabtech. If you want cheaper, Zone offroad (made by BDS) if you want Cheapest, and in my personal opinion not nearly the best... Rough country. If you want ultimate cheap. just throw a body lift on and call it done. Retain the ride you have now while giving you the extra height and clearance for the tires you want.
    rayredbone
    rayredbone
  • Who's Online   1 Member, 0 Anonymous, 525 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
